Hi, recently I built a Hi-Res Music Player with support for FLAC/WAV/MP. I just used all old hardware lying idle with me. It is on top of Intel NUC, Linux, 1TB Hard disk drive and Fiio USB DAC. I have given my complete console logs to get it done as reference for others and myself too for future
Hardware components:
1. Intel NUC 5i3RYH with 8GB RAM and 1TB Hard disk drive. HDD should have a small 30GB partition for / file system and rest goes to /home to store Hi-Res music files.
2. Fiio E10K USB DAC
3. Pen drive with Ubuntu Servver 18.04 Linux Installation image. I don't use Ubuntu desktop. It is a headless server without Monitor/KBD/Mouse.
Installation Steps:
1. OS Installation:
Install Ubuntu Server 18.04 using pen drive image and ethernet connected.
2. Wireless configuration:
$ networkctl
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 enp0s25 ether routable configured
3 wlp2s0 wlan off unmanaged
$ networkctl status
● State: routable
Address: 192.168.1.20 on enp0s25
fe80::xxxx:edff:xxxx:xxxx on enp0s25
Gateway: 192.168.1.1 (NETGEAR) on enp0s25
DNS: 192.168.1.1
Only ethernet configured in above console log. So wireless to be configured
$ sudo apt install network-manager
$ nmcli dev wifi
IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY
-- Infra 2 65 Mbit/s 74 ▂▄▆_ --
ssid1-5G Infra 36 270 Mbit/s 44 ▂▄__ WPA2
ssid1 Infra 2 130 Mbit/s 25 ▂___ WPA2
Now configure
$ sudo nmcli dev wifi connect <SSID> password '<Password>'
Device 'wlp2s0' successfully activated with 'd10a020e-32bd-4058-89ac-5e4ff1630a8f'.
$ networkctl status
State: routable
192.168.1.25 on wlp2s0
fe80::XXXX:edff:XXXX:XXXX on enp0s25
YYYY::f57b:YYYY:3803:YYYY on wlp2s0
192.168.1.1 on wlp2s0
DNS: 192.168.1.1
Wireless Done!
3. SAMBA server for File sharing (to copy Music files over network):- assuming you have a normal user called "audiouser"
$ sudo apt install samba
$ sudo smbpasswd -a <linux_user_name>
Append below snippet in /etc/samba/smb.conf
-------- start --------
[Music]
path = /home/audiouser/Music
valid users = audiouser
read only = no
--------- end ---------
$ sudo service smbd restart
Below cmd to check if any error in smb.conf
$ testparm
4. ALSA audio base installlation:
$ sudo apt install ubuntu-restricted-extras => installing media codecs
$ sudo apt install alsa alsa-utils
Note down
$ cat /proc/asound/cards
0 [HDMI ]: HDA-Intel - HDA Intel HDMI
HDA Intel HDMI at 0xaa124000 irq 46
1 [Audio ]: USB-Audio - DigiHug USB Audio
FiiO DigiHug USB Audio at usb-0000:00:1d.0-1.3, full speed
2 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xaa120000 irq 47
Test from cmd line:
$ speaker-test -Dhw:1,0 -c2
Make the device default:
$ sudo vi /etc/asound.conf
defaults.pcm.card 1
defaults.ctl.card 1
$ alsamixer => adjust all volume for your card
$ sudo alsactl store
4. Hi-Res Music Player Daemon installation:
$ sudo apt install mpd
Edit /etc/mpd.conf => Here change media path directory as your music files and HW ID as DAC.
copy all Music files under /home/audiouser/Music => use same path in above mpd.conf file too
$ sudo service mpd restart
5. Install MPD client in Android/iOS and enjoy
Installation Steps:
1. OS Installation:
$ networkctl
$ networkctl status
● State: routable
DNS: 192.168.1.1
$ nmcli dev wifi
Now configure
$ networkctl status
State: routable
DNS: 192.168.1.1
Wireless Done!
[Music]
read only = no
$ testparm
Note down
Test from cmd line:
defaults.pcm.card 1
defaults.ctl.card 1
