diy lcd projector from chennai
hello all i hope you all mistaken me !!
i am from chennai but i work in qatar i am an instrument supervisor !!
i got all the information from lamens lab !!!
Lamens Lab? What is that?
If you take a piece of paper, punch a small hole, and throw a light through it, you have a projector. That is the basic principle. But, with real life projectors, the heart is something called a DLP chip invented by Dr. Larry Hornbeck in 1987. In essence a light switch, the DLP switch has 2 million tiny mirrors that move on hinges. These mirrors project a light source either towards the screen or away from it giving you tiny pixels on the screen that form the image. The DLP switch can work with 1024 shades of grey and about 17 million color combinations. When you talk about a 3 chip projector, you are talking about some 35 trillion colors!
Controlling these mirrors needs a computing power far larger and faster than what you have on a standard PC.
So when you come and tell us that you have made a DIY projector, should we not take it with a pinch of salt? Unless you come with some solid proof that you really have something working in terms of photographs, I am afraid no one is going to believe you. And the photos have to be authenticated somehow as being yours.
We look forward to seeing your projector.
Yes Lumen lab -> Projector Builder
I got the parts from Philippines!!
Projection lens
fresnal lens
Reflector (dichronic)
Condenser lens
7LCD wide screen
Osram 150w MH lamp
woden box
@Venkat, I really have to disagree with you. Have you ever seen a DIY projector based on a single LCD?
I had made one sometime back using a 15" Benq 1280x720p (native) monitor HD projector and the total cost came to only around <16K and watching HD content was really good, it was comparable to the branded products (apart from some minor issues) with a fraction of the cost. Lot of people had made decent PJs out of Full HD panels also, since it was not available in India (within reasonable size), i had to settle for 720p.
Its not a rocket science. I had bought the Fresnel lenses and Triplet from Lumen Lab. Bulbs (MH from Osram 400w) and ballast locally. Since size is one of the limitations of DIY PJ (in Living room), I had to settle for a readymade PJ with 5" LCD which supports 720p (native) which I bought from canada for 13K INR along with 2 bullbs. The size and shape is same as commercial PJs. PQ and brightness was better when I was using the 15" because of the tight dot pitch than the 5". Anyways the PJ is giving acceptable PQ for HD on projecting to 100". Brightness is slightly lesser since it is using a 150w MH ceramic bulb, probably I may tweak it with my previous bulb.
Advantages of DIY PJ:
- Big screen at a fraction of the cost of commercial PJs
- Bulb life is around 10000 hrs (min 6000-8000hrs)
- Replacing a bulb will cost very less (~2000/- for my current PJ. I may not require as it came with another bulb as a freebie). My previous Osram bulb costed only 750/- with same life time, but it was not compact as the ceramic bulbs.
Disadvantages:
- Lot of tweaking required to get the desired PQ
- Size will be very big (based on the lcd panel)
- Very difficult to make it silent as other PJs
Edit : I am planning to put my Lumen Lab Fresnels (split / 2Nos / .5mm) and Triplet for sale, I will start a new thread for that.
Projection lens
fresnal lens
Condenser lens
7LCD wide screen
Osram 150w MH lamp
woden box
Then why you are afraid of showing photographs?
And do not lift from net ,members here have on board hi fi image searching enabled in their brains!!!:ohyeah::ohyeah:
Deal All,
Please find the photos of projector and results:yahoo::D:D:D
wonderful efforts Technician..:clapping:..I hope your next attempt would be more refined in both looks and performance....
My apologies Sajith, till I heard about the lab, I had no idea that you could make PJ as a DIY.
And technician, good work.
Technician
Nice work
welcome here..
Buddy sorry for funny tone which you may find insulting..in the past there was a person who used to show us his DIY KALAKARI ,onlky intention was to sell something at very high price!!
It would be great if you tell us more
1) Source websites
2) Bill of material
3) Time taken
thanks
Technician
Nice work
welcome here..
1) Source websites
2) Bill of material
3) Time taken
thanks
I asked the same stuff in post no 2 when this thread started, but till now no updates on the same.It will be great if you can share the knowledge,cost involved and experience
from the look of the PJ..it would not be more than 12k-15k rupees.....most pricey being lcd, lamp and ballast if there......I once wanted to do a diy pj.....so did some surfing....figured out that...it is the cheapest option for PJ...but...size wise its tricky job.....
Technician...like others have asked kindly respond to the mentioned queries...
Venkat
If it is a non HD projector, it would be around 8 - 10K.
For my PJ,
- lcd monitor : 6500/-
- LumenLab Fresnels and Triplet lenses + other related expenses : ~125$
- Osram 400W 5200K MH bulb : 750/-
- Ballast : 1250/-
- Box
Strippling the lcd monitor is the risky part in this, if you mishandle the ffc cables around the panel from the controller can make the lcd dead. Also finding the compatible lcd without any ffc issues (in the light path) is another tricky thing, you will get to know only once you strip it. Usually Benq lcds dont have this issue.
Reducing the size is again another tricky job. It can be done by folding the light path using mirrors (front coated, not the normal mirror). By folding the light path by 1 or 2 folds inside the box can reduce the size and length of the box.
Venkat
@Technician, please post your PJ costs and if possible some closeup shots of the projection as it seems this is new to lot of forum members.
Dear all!!sorry for the delay !!because i am in QATAR !!SAUDI !! i can post in luch &fridays only !! ant way here we go !!
Cost of the projector 16K but lot of effort!! During my vacation (March)
I have made this box jest for measurement!! & placing the lens
Sure will make good box when I come to Chennai!! My vacation august 2010
Material I have already posted which I have used,
You can get the lens in used old OHP
Triplet lens (projection lens) OH projector (best)
In some OH projector single lens only!! (Dont use)
Fresnal lens also used in OH projector but the thing is lens must be in good condition without any scratch
Will send you more detail in next post /
Tech
:cool::ohyeah::)
i asked my son to send me some inside photos
of projector from chennai
soon will send !!
this attachment from my frend in phillipiens
cheers :ohyeah:
