flat_listener
Now, FMs of Hyderabad know where to look if they need Oxygen concentrator
Unlike personal portable O2 concentrators sold commercially, this is of much higher capacity and much more bulkier. Hence the Hyderabad specific comment.@captrajesh
FMs of HFV would be more apt...
I have witnessed both of them working. Even the smaller one is not portable enough."Below is a small foot print compact version with 1HP compressor and 1Kg Lithium Zeolite per Sieve bed. Outputs 8LPM @94% purity".
He also mentioned about a small footprint machine being developed...
Hence the HFV specific suggestion.
Superb - initiative. Very inspiringMounted the compressor and Arduino controller:
Wired the controller and powered it up... all the relays were switching in sequence as per the code:
Next task is to connect the tubing and solenoid valves:
Same here - I was just looking in for Oxy Concentrator. I saw this remarkable initiative by you and well documented. I want to built and distribute and donate in villages - its really disheartening to see people die. Can you please help. Would be ready to invest and produce here in your guidance.Yes @sud98
The O2 shortage situation is alarming. I am seeing a lot of interest from people wanting to build these machines from various parts of the Country.
One example, couple of days back i received two PMs showing interest in OxiKit build. Both are new members joined same day. Further, they revealed they joined the forum after reading my thread and not for AV purposes, but just to connect with me.
Probably they are the only members joined the Forum for reasons other than Audio... they formed a Whats App group with the residents of their society and are making plans to go ahead with the build.
That's the power of HFV.
Would like to replicate this effort. Can you please share the BOM/suppliers? That would be very useful.
@hydrovac
Any suggestions where to source oxygen sensor KE-25 and the second sensor you used.
Great work. You have put lots of efforts. It will guide many others.
Congratulations sir. I am from Kolkata trying to build the same. Can you guide me please ?Thanks
@MaSh
@quad
Update:
For the past 3 months did lot of trials with different parts, Zeolites and codes, to achieve optimum results.
With Jalon Lithium Zeolite, got the best output 14LPM @95% purity.
V2: With Air receiver tank, Better moisture separation with auto drain (99.9%), bigger fans on the compressor.
Below is a small foot print compact version with 1HP compressor and 1Kg Lithium Zeolite per Sieve bed. Outputs 8LPM @94% purity.
Also fabricated second Analyzer with less expensive O2 sensor and IC, cutting cost and also size by 40%
Hi,Congratulations sir. I am from Kolkata trying to build the same. Can you guide me please ?
Yes,Looks very neat and professional. Considering the prices of the concentrators (we bought one for our community at 1.2l for a 7lpm concentrator. I suppose zeolite would be a major bottleneck, considering the govt. sent a plane to Italy to procure the same, right?
Our best wishes. If it could be covered up from all sides, that would make the package complete. BTW, waiting for inputs from whom?This is the machine I am building for sending to field trials and also to get Accreditation for the Device.
Waiting for the inputs regarding the mandatory safety features to be introduced in the design.
@hydrovac hello, appreciate your work. am from faridabad. i have questions. (1)how much did it cost to build 15lpm & 8 lpm.(2) how long in hours continuously was the kit tested. was there a degrade in o2 concentration? (3) how about humidity control. also is it possible to share build docs as i would like to develop two prototypes.thanks.Thanks
@MaSh
@quad
Update:
