elangoas
Hi All,
Been reading some articles on room acoustics and some previous threads on this forum as well as other forums related to the topic.. I don't know if am right, but low density Broadband absorption seems to be one of the solution to address modal responses..
Here is a response of dual subs + Fronts..
From 10Hz - 20Khz..
From 10Hz - 500Hz..
and my living room room layout.. Room height is 9feet, 7 inches..
Am still trying to minimise the peaks/dips in sub-woofer range by re positioning dual DIY sealed subs in the room (or) would add 2 more if that would help for a smoother response below 80hz..
Above the sub-crossover range of 80Hz, to minimise the peaks/dips in the modal responses the most common suggested solution seem to be 6 inch of absorption on the front wall & part of back wall.. This being a living room, am limited with options to place 6 inch thick panels on walls.. There is lot of space in the ceiling that i can use.. Abt 18 ~ 20 inches from ceiling, i have no issues to use them..
Would it be better to use the entire ceiling space of 14 (W) x 11 (L) X 1.5 (H) feet for absorption in the room?.. Would absorption on ceiling help.. If so, how much thickness is good / how much area is good?..
If adding absorption to ceiling will not help, i will re-consider walls..
From 10Hz - 20Khz..
From 10Hz - 500Hz..
