This is how i executed.. ![]() ... |
I'm the kind of person who doesn't believe that a power cable could make a difference until and unless the older one was damaged or very low quality. But your results are encouraging.Wanted to update everyone on my DIY power cable journey.
I had an extensive listening, testing the new power cords... actually i have three components, but only two new cables, so used this cable i already had on the CD player.
Believe it or not, sound stage and dynamics are the first victims of a lessor power cord...
I have found that source components show a greater improvement, I suspect because their power supplies are not as "able" as those generally found in power amps.
The improvement in sound quality, and especially quietness and impact were unreal.
Dynamic performance, clarity and imaging are probably the most noticeable improvements across all components.
I have yet to receive the wall receptacles i ordered.
Things to try in the future:
- Using different IEC and power connectors. I found a source for wall-sockets. My main purpose here is to get better connections.
I replaced the power cables of my dac and marantz amp with these lapp cables without any fancy connectors. This has transformed the sound. Its more smooth, bigger soundstage, more easy to listen to and enjoy. More air around notes and music seem to flow better. Must have for any kind of audio setup. Replace all power cords with these inexpensive cables.FURUTECH: (This is the costliest of the lot)
FURUTECH FI-11M-N1 (G) Gold-plated Schuko Plug + FURUTECH FI-E11 (G) Connector IEC: US $65.00
Black & Yellow 16mm Braided PET Expandable Sleeving: US $3.00
Pre-Cut Heat Shrink Sleeve (Tube) 18mm x 100mm (10 Pcs): US $1.00
LAPP OLFLEX CLASSIC CY 2.5MM SHIELDED AUDIOPHILE GRADE POWER CABLE (Meter): ₹535.00
you can convert the amount to INR for total cost.
Great looking cables, and top class DIY!
I am tempted to fabricate couple of cables for myself... but restricted with my limited DIY skills.
Can you pl guide me?
Tempted to try diy. Maybe not with these high-end connectors.
Used this to replace stock rega cable. I don't find much of a difference, maybe my untrained ears. I will try replacing the dac power Cable and see if that makes a difference.Taking inspiration and advice from @hydrovac, I just completed my first power cable with sonarquest connectors that I sourced from USA. Haven't used a sleeve and heat shrink tubing though. Now I will have to try this cable and see what difference I notice.
Trying to attach pics here. It says file too large. Need to minimize it.Can you please post few pics of the build?
