Do i require step down converter & stabilzer for 48 inches LED TV bought from USA
This is what I found on the TV power adapter.
The adapter shows that the voltage rating is 110 volts - 240 v at frequency 50/60 hz.
With this i feel that i do not need any step down transformer.
Still, i feel it would be better to use a voltage stabilizer.
Please suggest..
Hi, I also bought LG TV in USA and brought to India . Here is the info I found in TV back side. Please confirm does it required converter or not? Only Stabilizer enough
Please suggest..
I also bought TV in USA and moved to India and need to use this TV ..can you please confirm does it required converter or not?
Looking at the attached image, it does mention 100-240 volts, in which case you won't be requiring a step down transformer. But do get a voltage stabilizer from v-guard, check with any TV stores for exact model.
