Got a new JVC DLA-X55 4K projector , the guy who installed it says despite what i think that the bulb problem is only in the older bulb type projector and that a ups is not need even if there is a sudden power outage nothing will happen to the projector.
As far as my understanding goes with frequent powercuts, and switching off the projector without a proper shutdown reduces the lamp life, Please advice
JVC DLA-X55R Home Theater Projector Review
[IMG2][/IMG2]
As per the manual
[IMG2][/IMG2]
As per the manual
Turn off the power
Remote control: press the (D [STAND BY] button
Projector unit: press the ')/ I [STANDBY/ON] button
While the Are you sure you want to turn off? message is displayed, press the button again.
The lamp turns off, and the STANDBY/ON indicator switches from a green light to a red blinking light.
After the light goes off, the fan will run for about 60 seconds to cool down the lamp (Cool-down mode)
Do not disconnect the power cable while cooling is in progress.
After about 60 seconds, the STAN DBY/ON indicator switches from a blinking red to a solid red light.
STAN DBY/ON blinking (red) STANDBY/ON lights up (red)
In the Cool-down mode In standby state
CAUTION
The power cannot be turned off within approximately 90 seconds after it has been turned on.
The power cannot be turned on again while cooling is in progress (60 seconds).
Pull out the power plug when the unit is not to be used for a prolonged period of time.
