Dynamic range expander system
vmscbe1974
coimbatore
I recently bumped into toshiba's dynamic expander system Aurex AD 2 and technics Su9011 stereo preamp. Kindly let me know if these are good systems for vinyl listening.
Srinivas
Srinivas
As per my understanding the AD2 was a noise reduction unit designed for use with Tape sources. Not sure if it would do any good for phono listening.
Personally I've never been a fan of the phonostages on Technics amps or preamps as they tend to sound very thin and shrill. I've always preferred the smooth sounding, neutral NADs. However suggest you listen to it and attempt to ascertain whether it fulfills your listening requirements.
Have been asked this question many times as I assume both these amps are available on the preused market currently.
The 310 is a low powered integrated amp, commonly referred to as the "baby NAD". It is also known as the amp for the audiophile on a budget. Its rated around 20watts per channel but can produce some bigger sounds with the right speakers. However, since NAD kept it basic, it lacks a phonostage, hence you'll have to use an external one. My opinion - nice for a CD or Tuner based bedroom setup or ok for book-shelf speakers for tiny living rooms.
The 705 on the other hand is a stereo receiver, ie it has an inbuilt tuner. However i must say that this is one from the early 1990s. It is rated at 40 watts with an 8ohms load and comes with an inbuilt phonostage. The tuner is alleged to have the famous NAD 402 circuit and the amplifier section from the NAD 304 integrated amp. Given the fact that the 304 had a great phonostage, this amp is also likely to have a good one, which is the trademark of all older NAD integrateds.
Personally, if you ask me to make a choice between the 2, I would go for the 705 as it is a good integrated with an inbuilt Tuner and phonostage. However, I suggest an audition before making any audio-related purchase decision.
Pricing is very subjective depending on a lot of criteria such as overall cosmetic condition and functionality, previous ownership history, service history, whether being purchased in person on cash payment or via shipping, etc. Without info on all these aspects, I would say that vintage low to medium power NAD integrateds are usually priced in the 6k-12k range depending on these factors. The NADs that are currently in production or just out of production are priced higher. NADs purchased New from Indian dealers are usually priced heavily in the Indian pre-used market.
I'm with reubensm on the NAD recommendation. Great entry level high-end equipment.
NAD also makes phonostages (pp-1 and the better pp-2). What's your budget? If you can, go for the Cambridge Audio Topaz AM10 integrated amp with built in phonostage. Should be a step up from NAD.
i have opted out of technics pre amp as stated by reubensm i wasnt happy with the outcome. prefer Nad as it sounded better. yet to try other model. I have cambridge 540 pre amp.
regards
Srinivasan
good info,NADs purchased New from Indian dealers are usually priced heavily in the Indian pre-used market. thanks
nqpSam
I heard the PP-2 in Mr. Kuruvila's setup, last week and also in the past. lt sounds very good and can easily outbeat some higher priced phonostages. But by Indian standards, its still a bit on the expensive side.
