Mid range phono stages
Softone Model4 hybrid phono amplifier are worthy to consider - imo. Does not use a negative feedback and all stages are directly coupled.
You can’t go wrong with the EAR 834. It’s a special phono.
I hope the new EAR Phono Box is as good or better than the 834
Thanks for the guidance - I am settled for a year or two. By then I hope to solve the room issues and also get to my destination speaker and amp.
I don’t think you have any any room issues. You just need to work on the speaker placement.
Once you get your speaker placement right, the position will be pretty much the same for any speaker you buy later. At most a couple of cms here and there.
Arjun did help in doing some changes the other day - it sounds much better now.
There is still a mild amount of echo to fix though. Clap test leads to a bit of echo.
ROC, maybe try some absorption at ceiling corners. Try a simple pillow at the top corners and see if it sorts out.
Is the room carpeted?
