Earphones for iPhone 4
rahuljonline
Kolkata
Hi guys,
I'll be buying an iPhone 4. I'm looking for decent earphones. Right now I'm using the creative EP-630 with iPod shuffle. I would like something better than this. I can go upto Rs. 3000 max. So, want to ask your opinion.
How how about Seinhessier or Brainwave M-2?
Please suggest something, as I dont have much clue...
I mostly listen to Rock music, classic, heavy... everything...
Thanks in Advance.
Hey I saw a nice deal on ebay Global-buy for " klipsch image s4 " , which is Priced at Rs3439. I have a 500 rupees off coupon so it becomes Rs 2939.
You can research about the quality online. It is supposed to be amongst the best IEMs below 100$
Personally, I did not like S4 that hugely. It is a major step up from EP630 though.
The choice of IEMs within India is very restricted. The IEM market under $100 is littered with many choices if one is open to buying online internationally. I am going to try and make one post without a recommendation of Brainwavz (They are very good phones, but I am a bit tired of every thread on IEMs here / TE containing a reference to M2 / M3 as a recommendation. So, let me at least make an attempt)
A few choices:
DUNU Trident ($35 from MP4Nation with a month's wait, $40 from Lendmeurears on eBay not much wait)
I have not heard this personally. But, it is a very decent IEM based on what I've read and personally told by others on head-fi. It's cheap, but the build quality and accessories are said to be very good. Isolation is very decent, but not perfect. I am also told that people with smaller ears could have some trouble with the housing design. Here's what I could gather about them so far - good for the price but not extra-ordinary enough to be compared against $100+ IEMs, musical, good sound stage, good bass but not huge quantity, V-shaped with airy, crisp treble and decent mids. Should be a very nice step-up from the constrained sound stage of EP630. Here's a review on head-fi. As it happens with all new IEMs, take this review with a pinch of salt - comparisons to the $250 DDM2 and $300 SM3 are to be ignored.
SoundMagic PL50 (About Rs. 1900 shipped from Lynx, if they have it in stock)
If you seek a different flavour from EP-630, PL50 could be it. Unlike Trident, I've heard the PL50. It's housing is very small and comfortable to wear. The build quality is not very great as it's all plastic. Coming to sound, PL50 is bass light for sure. But, what you lose in bass when coming from EP630, you will gain in the other two ranges. Mids of PL50 are lush, crisp and really non-fatiguing to listen to and treble is crisp and sparkling (might be the biggest difference from EP630). Sound stage is good as is imaging. The balanced, neutral, bass light presentation of PL50 is almost opposite to the muddy bass, small sound stage, not so great treble presentation of EP630. However bad I think of EP630's sound, it was my first IEM and for a while, the most comfortable. You won't miss that with PL50 as it would be comfortable due to the tiny housing which disappears into your ear.
Xears XE200Pro (30 Euros + 8 Euros shipping from Xears.com using coupon code KLANGFUZZIS)
Xears is a German based co, a single man operation (as far as I know) that re-brands the Chinese OEM phones (like MEElectronics and countless others do). The build quality of the blackwood XE200 is not great. Xears is always known for it's driver flex, the pressure 'noise' it makes whenever the IEM is inserted into the ear. It's not good for the IEM in the long run, but I have not had any failures apart from one TDIII v1 (which was due to bad cable) out of the 10 models I've owned so far (Don't ask - it's cheap and I am an IEM addict).
XE200 uses what Thomas calls a "textile cable", which is just a fancy translation for cloth sleeved cable. The accessory set is spartan and most times, not up-to the mark, though the quality has been gradually improving from the older sets like Playaz N1 (but only long-time customers know that :p). Why the hell would any one recommend a German 'brand' with so-so build quality?
Whatever points Xears loses for external factors, it makes up by gaining brownie points for the sound. XE200 is balanced, but with a wide, "open feel" sound stage. Xears are generally known for the huge, pumped up bass especially the mid-bass hump, but XE200 has just a tad more than the "correct" amount of bass (< TD & XT series). Even with the relatively less quantity of bass, it has enough to beat PL50 by a mile and more. It's mid range is placed a tad distant and treble is a bit sparkly.
While I'd speculate that Trident would be "musical" with enhanced bass and treble, PL50 is an example of slightly dry, neutral signature, XE200 is balanced without being boring.
There are many other interesting IEMs, but I'll stop with three for now.
Rahul, The iPhone 4 is a very good source. And there are plenty of options in your budget of 3000rs or 60-70$.
Personally, I would suggest you take a look at:
1. Ecci PR401: They look a bit plain jane, but are very comfortable to wear. Though they dont look like it, they are well built and can take abuse. The flat cable does have a bit of microphonics. As for the sound, I love it. Slightly V-shaped, but the mids are quite ok,even though they could do with a bit more body and timbre. But the best part of this iem, is its airiness. I have not heard something as airy as this in this price range. The bass extends well and so does the treble.
2. Xears TD-100 III: Punchy bass, sub bass as well as voluminous mid bass, warm mids and beautiful timbre make it a very enjoyable sound signature. They compromise a bit on speed and that fine bit of detail though. Also you have to handle them carefully, as the build quality is not their forte. The new version with the textile cable hopefully address that. But they are a very vfm proposition for their price.
The new xe200 is another option but I have not heard it personally. I have heard the M2, they are pretty good but I prefer the PR401 and TD-III a bit more.
Well...
You can buy from Sennheiser.... Also you have an option to get from online market... Which the way easier you select that...
Hi guys,
I bought the iPhone 4, 16 GB. Also ordered the Sennheiser MM-50 iP from ebay. Waiting for it to arrive.
The iPhone is just oooooh.....
Thanks so much for your help!
Cheers!
congrats! So why did you choose Senn mm50?
It is a sort of a blind purchase. I could not audition or even see any of the earphones, so online purchase was the only option.
I read the reviews and narrowed it down to S4i and MM-50. I found out from reviews that MM-50 has good bass (not neutral). Thought of going for it. Let's see how it goes. :)
I use Sennheiser CX 400 II and they are excellent. Have ordered Sennheiser IE9 from US. Bose earphones, I dont know; i feel like they are no where near Sennheiser quality. Just the hype.
You should have stopped with 'I dont know'. You don't have an opinion until you hear them.
I have heard them many times. Thats why I said, its just the hype. Few of the headphones are really good in Bose but again they are too expensive. Somehow i feel Sennheiser is worth than Bose.
Sent from my GT-I9100 using Tapatalk
