Thank you!Look at TAGA or Yamaha speakers......also you can consider Boston Acoustics if available.
Sent pm.Hello Folks,
I am looking for some advise.
Best economy HT speaker system to go with Yamaha RX-V685. I am looking for a 5.1.2 setup and my budget is a lakh. My room size is 15 (length) X 15 (Width) feet and height 8 feet below the false ceiling.
Your help will be highly appreciated.
IC
How's the performance of Yamaha Dual SW300 ?Try this Setup Yamaha NS F71 + NS P51 + Yamaha Dual SW300 . I have the same setup with RX-V 585 .
You may need to spend a little more for Front Heights Speaker .JBL control One is an option
All are good but I would strongly advise you to get a better sub. A sub alone will spoil ur entire set up. You can just finish a 5.0 set up and save somebody money and add a sub later.Thank you all for the details. I have zeroed in the below. Please let me know your thoughts
Yamaha NS-555 towers speakers
Yamaha NS-P350 center & surrounds
Yamaha NS-SW100 subwoofer
Apart Audio CM608 ceiling speakers
Thanks again amigos for taking your time!
Sw300 will cost u 26-28k. Bic f-12, Taga platinum sub 30 k range and bic pl200-ii 40k. Also audition Polk Hts 10 and 12 in 30-35 k bracketThanks! Any recommendations ? NS-SW100 is costing 16K.
Yeah please,sub is very important for movies.Thanks and its really interesting; I will definitely give a thought.
Just have a relook on the Sub as this will not satisfy your powerful Front Speakers.Thank you all for the details. I have zeroed in the below. Please let me know your thoughts
Thank you!Just have a relook on the Sub as this will not satisfy your powerful Front Speakers.
Not Nessasary to go for a 5.1 good stereo system is enough too since budget low. Go for a Good stereo and you will have better Music and movies experienceHello Folks,
IC
