Rca not sure whats the issue but optical that sounds correct. From whatever I have read about them (I don't have any yet) the edifiers cannot decode dolby or dts via optical. Only pcm signals. Owners can correct me if I am wrong.
Post your reviewOrdered Edifier R2850DB based on online reviews. Buying this primarily for tv (instead of soundbar) for movies along with some music listening.
Are there any other owners? Is there a subwoofer needed for movies? Please share your experience
I recently moved houses so was looking for a soundbar for my tv. Wasn't finding anything worthwhile. I already have a setup in my home pioneer AJ series paired with a yamaha reciever. With the prices of similar setup prices off the roof currently. I wanted something light on my pocket. Went for multiple soundbar tests but i didn't like anything at 20-30k pricepoint. Finally bought edifier 2850 at 26k. Note that this was a downgrade for my ears. For tv soundbar replacement this is amazing at this price point. Woofer is a bit boomy. The speakers are huge so make sure you have the space. I watch movies / shows for long hours. No need to buy a woofer separately. For music i find them bass heavy and lose out details so i stick to my headphones. The remote is really bad. Overall i am ok with what I bought as a soundbar replacement.Post your review
Same here... I watch movies/series for long hours.I recently moved houses so was looking for a soundbar for my tv. Wasn't finding anything worthwhile. I already have a setup in my home pioneer AJ series paired with a yamaha reciever. With the prices of similar setup prices off the roof currently. I wanted something light on my pocket. Went for multiple soundbar tests but i didn't like anything at 20-30k pricepoint. Finally bought edifier 2850 at 26k. Note that this was a downgrade for my ears. For tv soundbar replacement this is amazing at this price point. Woofer is a bit boomy. The speakers are huge so make sure you have the space. I watch movies / shows for long hours. No need to buy a woofer separately. For music i find them bass heavy and lose out details so i stick to my headphones. The remote is really bad. Overall i am ok with what I bought as a soundbar replacement.
Check, if add any DAC...To may enhance audioNote that this was a downgrade for my ears.
Hi, how's ur feedback regarding the T5 ? Is it worth going for it instead of the bigger powered ones. Was planning on a setup identical to yours and on the verge of buying. Ur inputs would be highly appreciated. TIA...I own a R1700BT for almost 2 years and have recently paired it with a Edifier T5 Subwoofer. I use PC. Thinking about a upgrade, stuck between getting a external DAC or a better bookshelf speaker (S3000 Pro or Airpluse A300 Pro). Any suggestions? Im thinking about selling my whole current setup.
The above models from edifier are value for money. Make sure the connectivity options and Bluetooth version before finalizing. Model name ends with DBs means digital, Bluetooth with subwoofer out. BTs means just Bluetooth with sub out, it goes like that...Folks , Need suggestion on Bookshelf/Tower speaker . My requirement is mainly to listen to music wirelessly . Hence need latest Bluetooth 5+ versions . I like moderate bass but the echo/humming sound of bass. My budget is around 15K INR . The following Edifier Model are available in Amazon.
R1280DBs
R1700BTs
R1855DB
Can you suggest which one would be a pick for my taste and long term reliability . If there are any other online reliable market place to buy speakers let me know or any other brand models within this price bracket . Thanks.
Thanks . Any idea on the sound characteristics difference between the R1280DBs & R1855DB ? which one will be more suited for music . How is the Bass delivery ?The above models from edifier are value for money. Make sure the connectivity options and Bluetooth version before finalizing. Model name ends with DBs means digital, Bluetooth with subwoofer out. BTs means just Bluetooth with sub out, it goes like that...
I am using 1700 bt for my TV and I am quite satisfied with the sound it produces.
I haven't heard any of the above two models.. but the 1700bt which I am having is more similar to the 1855db except the connectivity part. So assuming it may sound similar to 1700bt, which is having descent bass and nice midrange. Bluetooth reception range and quality is also acceptable. One thing which is bad about it is the remote control, which might be improved with the 1855db version.Thanks . Any idea on the sound characteristics difference between the R1280DBs & R1855DB ? which one will be more suited for music . How is the Bass delivery ?
And r1280 is budget oriented entry level.I haven't heard any of the above two models.. but the 1700bt which I am having is more similar to the 1855db except the connectivity part. So assuming it may sound similar to 1700bt, which is having descent bass and nice midrange. Bluetooth reception range and quality is also acceptable. One thing which is bad about it is the remote control, which might be improved with the 1855db version.
What I read about 1280 model is it's with less bass than the 1700 or 1855 models .. it's strength is the midrange.
hi i am thinking fo buying these speakers...did you get them ? how do they sound ? thxOrdered Edifier R2850DB based on online reviews. Buying this primarily for tv (instead of soundbar) for movies along with some music listening.
