Emotiva Airmotiv C1 center channel Initial impressions
Hi i recently joined the forum. I had been using Elac cc 51.2 as the centre and looking to upgrade to emotiva. I live in annanagar. Would it be possible to audition - somu
Yes, you can drop in my place to check the speaker.
Excellent stuff mate! Congratulations and a nice writeup too! All the best! :)
I am also using the Emotiva Airmotiv C1 and its a excellent center speaker.
can anyone compare emotiva C1 vs C2?
I am confused on which one to choose for my HT.
My setup will be in a 9ft * 22 ft room. Listening distance is approx 10ft away from Center speaker.
It is to be paired with emotiva B1 front channel.
If i were in your position, I would just get the biggest fattest Centre channel I could afford. The front soundstage is really the key.
but will that me an overkill for the small/medium room?
will they overpower the Left and Right speakers?
-- I cannot have tower speaker due to room limitation.
It wont be an overkill Rejin for home theater usage.. Go for big ;). You can check with our @kaptan as well :p
It wont be a overkill, but still C1 will do the job for your room. There are chances C2 might dominate the front sound stage if using with B1s. So C1 will be a clever choice IMO.
What are the prices you are able to get for the C1 & C2?
Thank you Saketb. During the past 2 years , I demoed the CSI A6 twice during my hunt. I forgot to mention some of the speaker that had demoed during those 2 years for my center.
Monitor Audio Bronze center (Brighter for my taste & Pricier)
Sonodyne Sonus 2501 ( Does not have the wow factor that I was expecting)
Heco Victa ( Can be compared with CSI A4 both are similar in my point of view)
CSI A6 was a stand out from the crowd. There is a big difference between its younger brother CSI A4. But what to do the speaker which I haven't had the demo at all got its place in my HT:lol:.
Can you please compare your Emotiva c1 VS polk csi a6, i am looking for a center upgrade hence asking.
I have both c1+ and c2+ and they are very good for dialogue clarity. It was better then my earlier center speakers (Pioneer/Dali/Elac). Sorry don't have direct comparison experience with Polk's.
Unless your room is bigger, c1+ will be more then sufficient for HT.
which dali speaker you comparing with c1 + or c2+, is it spektor vokal or oberon vokal?
im planning for speaker for both music and movies. i thought about spektor 2, q acoustic 3030i, emotiva b1+ , dali oberon 3
can u please guide me.
also let me know about height speakers, dali have many types and q acoustic too. please help
My experience was with Zensor center speaker.
