Hello all,
For quite long, i have a vibrating sound in my room. This is happening even without using a sub. By adding a sub, it is increasing a bit more. I taught some furniture is vibrating.
After observing and checking a lot, finally i found the false ceiling is vibrating. When I hold it up with slight pressure, it is stopping.
Please see the attached image where I highlighted the area. The opening is 6 inch deep x 2.5 inch wide. Can we stop this vibration by filling it up with foam or something??
Or should I change the place of my sub?? (It is placed on the floor at the right side of the laptop table.) I can't change place of my FS any way...
Any suggestions please??? Ofcourse, it is not unbearable, but it's a bit disturbing.
Thanks in advance.
Naveen
Structurally i can't add any reinforcement to add strength. Big exercise, any may not be worth doing.
But if the vibrations are due to "resonance" within the air in that cavity, it should stop by filling foam, or closing the cavity from the front side.
But if it is because of weak build quality, can't do much about it..... Just my taught....
Thanks in advance.
Naveen
