I maybe repeatign the post but good news for people wanting a HTPC solution but put off byt the cabinets.
I have the Silverstone cabinet price list and these are available in Mumbai (shipping charges are 600 rupees.
1 ML 02B MXR22 HTPC 15500 "
Acrylic front panel, 4.0mm aluminum frames, 0.8mm SECC body" MoDT Micro ATX, Mini-ITX, DTX Multimedia software, remote with on/off function, Multilanguage LCD/IR Slim optical x 1 3.5" x 1 or 2.5" x 1 (vibration dampening) - "
1 x 50mm exhaust fan, 2200rpm, 19dBA" 3 x 50mm fan slots Oversized venting holes - - 1 (includes 1 x PCI riser card and 1 x PCI-Ex16 riser card) "USB2.0 x 2
IEEE1394 x 1
audio x 1MIC x 1
52-in-1 card reader" Fanless 120W DC/DC board & AC adapter - "
4 kg" 397 mm (W) x 82 mm (H) x 375 mm (D) -
2 LC 10BE 00020 HTPC 8300 Aluminum front panel, 0.8mm SECC body ATX, Micro ATX Multimedia software, remote with on/off function, Multilanguage LCD/IR (LC10-MX only) 5.25" x 1 3.5" x 7 2 x 92mm or 80mm fan slots 2 x 80mm exhaust, 2050rpm, 21dBA 1 x 80mm fan slot & PSU vents - - - 7 "USB2.0 x 2
IEEE1394 x 1
Audio x 1
MIC x 1" Optional standard PS2 (ATX) - 6.4kg "
430mm(W) x 170.2mm(H) x 425.5mm(D)" -
3 LC 19B R0022 HTPC 11200 "
Aluminum front panel, 1.0mm SECC body (LC19R:0.8mm)" "
MoDT Micro ATX, Mini-ITX, DTX" - "
Slim optical x 1" 3.5" x 1 or 2.5" x 1 (vibration dampening)( LC19R only ) - 1 x 50mm exhaust fan, 2200rpm, 19dBA ( LC19R only ) 3 x 50mm fan slots ( LC19R only ) Oversized CPU/NB vents - - 1 (includes 1 x PCI riser card and 1 x PCI-Ex16 riser card) for LC19R "USB2.0 x 2
IEEE1394 x 1
audio x 1
MIC x 1
52-in-1 card reader (LC19R only)" "
Fanless 120W DC/DC board & AC adapter" - 3.9kg 390 mm (W) x 68 mm (H) x 348 mm (D) Slim optical drive IDE adapter
4 CW03 BMT 0010 HTPC 39990 "
All aluminum body, nickel-coated steel structural support" "
ATX, Micro ATX" 7" touchscreen, IR, remote with on/off function, iMON media center software "Native resolution: 800 x 480
Supported resolutions: 640 x 480 ~ 1920 x 1200 @60Hz" 5.25" x 2 3.5" converter bay x 1 3.5" x 6 (vibration dampening) - "
2 x 80mm fan, 2050rpm" - - 2 x 80mm fan, 2050rpm - 7 - Optional Standard PS2(ATX), maximum depth: 220mm Support to 11.25 inch length expansion card 8 kg "
430mm(W) x 184mm(H) x 436mm(D)" Touchscreen pen, 250mm D-sub connector, rackmount ears
5 GD02BMT 0020 HTPC 21500 Aluminum front panel & corners, SECC body Micro ATX, DTX, Mini-ITX 4.3 touchscreen, IR, remote control with on/off function iMON media center software "Native resolution: 480 x 272
Supported resolution: 640 x 480, 800 x 600, 1024 x 768" "
Slim optical drive x 1 3.5 x 1" "
3.5 x 2 (vibration dampening)" - 2 x 80mm exhaust fan, 2050rpm - - - - 4 "USB2.0 x 2
IEEE1394 x 1
Audio x 1
MIC x 1" "
Optional Standard PS2(ATX)" Compatible with expansion card up to 11.5 inch 7.86kg "
430mm(W)x155mm(H)x360mm(D)" -
6 LC16B MR220 HTPC 13500 Aluminum front panel, 0.8 mm SECC body Standard ATX, Micro ATX "
Multimedia software, remote with on/off function, VFD/IR" - "5.25 x 1
3.5 x 1" "
3.5 x 6" 2 x 92mm or 80mm fan slots 2 x 80mm exhaust fan, 2050rpm, 21dBA 1 x 80mm fan slot - - - 7 "52-in-1 card reader (LC16MR only)
USB2.0 x 3 (USB2.0 x 1 for LC16MR)
IEEE1394 x 2 (IEEE1394 x 1 for LC16MR)
audio x 1
MIC x 1" "
Optional standard PS2 (ATX)" - 7.3kg "
425 mm (W) x 170mm (H) x 425 mm (D)" -
7 LC16S MR220 HTPC 13500 Aluminum front panel, 0.8 mm SECC body Standard ATX, Micro ATX Multimedia software, remote with on/off function, VFD/IR - "5.25 x 1
3.5 x 1" 3.5 x 6 2 x 92mm or 80mm fan slots 2 x 80mm exhaust fan, 2050rpm, 21dBA 1 x 80mm fan slot - - - 7 "52-in-1 card reader (LC16MR only)
audio x 1
MIC x 1" Optional standard PS2 (ATX) - 7.3kg 425 mm (W) x 170mm (H) x 425 mm (D) -
8 LC 17B0220 HTPC 7600 Aluminum front panel, 0.8 mm SECC body Standard ATX, Micro ATX - - "5.25"" x 2
3.5"" x 1 (occupied by front I/O)" "
3.5"" x 6" "
2 x 92mm or 80mm fan slots" "
2 x 80mm exhaust fan, 2050rpm, 21dBA" 1 x 80mm fan slot & PSU vents - - - 7 "USB2.0 x 4
IEEE1394 x 1
audio x 1
MIC x 1" "
Optional standard PS2 (ATX)" - "
6.8 kg" "
425 mm (W) x 170 mm (H) x 425 mm (D)" -
9 LC 17S0220 HTPC 7600 "
Aluminum front panel, 0.8 mm SECC body" Standard ATX, Micro ATX - - "
5.25"" x 2
3.5"" x 6" "
2 x 92mm or 80mm fan slots" 2 x 80mm exhaust fan, 2050rpm, 21dBA 1 x 80mm fan slot & PSU vents - - - 7 "USB2.0 x 4
IEEE1394 x 1
audio x 1
MIC x 1" Optional standard PS2 (ATX) - 6.8kg 425 mm (W) x 170 mm (H) x 425 mm (D) -
Coolers
Sr.No. Model No. Enclosure material Application Net Weight Dimension Cooling fan Dimension w/fan Thermal Resistance Fan blade size Fan speed Max air pressure Max airflow Noise
Price
1 NT 07 - AM2 Cooler 1250 Aluminum AMD SocketAM2 330g "
106mm(W)x20.5mm(H)x80mm(D)" 80mm cooling fan "
106mm(W)x36.5mm(H)x80mm(D)" Rca 0.25 ? /W @ 65W , Full Speed "
80 x 80 x 16mm" 1500~2500rpm 10% "
0.63~1.85mmH2O" "
14.22~26.97 CFM" "
15~25dBA"
2 NT 07 - 775 Cooler 1250 Copper center, Extruded aluminum fins "Intel Socket775 45 nm :
Core 2 DUO E8000/E7000 series
Pentium Dual-Core E5000 series
Celeron D 400 Celeron E1000 series" "
310g" "
90mm cooling fan" 93mm (W) x 36.5mm (H) x 93mm (D) "
0.35(C/W)" "
1200~1800rpm 10%" 0.5~1.58mmH2O 12~23CFM "
15~23dBA"
Fans
Sr.No. Model No. Dimension Material Color Bearing Rated Voltage Start Voltage Operating Range Rated Current Rated Power Speed Airflow Static Pressure Noise Level Lifetime
Price
1 Suscool 121 Fan 675 120 x 120 x 25mm "
Plastic (PBT)" "
Sky Blue Blade & Black frame" "
Enter Bearing" "
12V DC" "
8V DC" "
8V~13.8V DC" "0.2 Amp @ 60?
0.08Amp @31?" "
2.4W @60?
0.96W @31?" "950rpm @60?
400rpm @31?" "42.15CFM@60?
17.75 @31?" "
0.57 mm-H20 @60?
0.10 mm-H20 @31?" "
18dB(A) @ 60?
15dB(A) @ 31?" "
30,000 hours"
2 FM 121 Fan 700 "
120 x 120 x 25mm" "
Plastic (PC)" "
White" "
Dual ball bearing" "
12 VDC" "
7 VDC" "
0.40A (Max. 0.45A)" "
4.8W (Max. 5.4W)" "
800 ~ 2400rpm" "
Max. 110.03CFM" "
Max. 3.26mmH2O" "
17dBA at 800rpm, 39.5dBA at 2400rpm" "
50,000 hours"
I will try getting the price update for Antec 2480 too.
PS: Could not include the xls because of size restrictions
