Hello issigonis,
Compatibility between the high sensitivity speakers you mentioned and the Lyrita amps is no issue. They will definitely play well together.
Your dilemna, as I see it, is different. Whether the sound played through these systems is totally to your liking, is the issue. Only you can tell. Whatever the pedigree of the components you select, how they make music together is what matters. How do you compare and contrast each of these system configurations? Human memory in these matters is rather fickle - it is difficult to transport over various systems in different locations. You actually have to live with a music system to get its true worth.
I suggest you lay stress on systems rather than individual components.
Viren
My understanding is as follows :
There are three 'systems' in my proposed hifi set up -
1. the analogue source comprising the 'components' : i. turntable, ii.pickup arm and iii. the cartridge
2. electronics comprising the components : i. phonostage, ii. line pre-amp, and
iii. the power amp, all with their separate power supplies
3. speakers
4. cables
I've finalised #1. I am trying to select # 2 and 3 by trying to eliminate systems which are incompatible.
This entails the following activities :
a. checking the compatibility between the cartridge and the phonostage ( I was told that a step up transformer is required for a Lyra MC cartridge even if the phono has one). Update : a phono which can handle both MM and MC won't require a step up transformer
b. my turntable will be a suspended, but well damped system. Will a full range/single driver, crossover-less speaker not be well matched with my well damped turntable?
I guess this might not be valid for all full range/single driver, crossover-less speaker brands, but confirmation is awaited, either way. All full range/single driver crossover-less speakers makers that I've contacted have said that they are fine fine with a SET, pure Class A, system #2.
c. All the reviews of the turntable have not been done with my type of systems #2 and 3. I am expecting that my overall outfit hangs well together ( plays music as it was recorded!)
Hence my concerns.
