baligavinod
Hello HFV members!
I registered newly here, but for weeks, I have been going through various threads on this forum in my quest to build my first ever HT build :yahoo:
I have shortlisted my requirements and restrictions. I will list my restrictions first as they play a major role in narrowing down on my build components:
Budget: I am on a tight budget (40-45k for now) but based on suggestions in various other threads, I am not going to go for a HTiB but instead go for an incremental build. Probably buy AV-Receiver and a couple of speakers for now (L+R). After that whenever I can afford I will add remaining speakers and sub.
Living Room Size/Shape: My living room is a bit longish in shape (20 ft by 13 ft) and TV Setup is in one of the corners. I don't think I can accommodate big bulky tower speakers on either sides of the TV without making changes to my furniture setup which would be a bit expensive
Now to the requirements:
So considering the above points, please advise me on how to go about it. I want to shortlist some options before I go out for audition/demonstrations. Also, it would be very helpful if you guys can suggest places to get demonstrations in Bangalore. Onkyo/Yamaha/Pioneer have a dealer close to where I live.
Thanks in advance for your precious advise and time :signthankspin: Hopefully I haven't missed anything while listing my requirements and constraints.
~Vinod
- Budget
- Living Room Size/Shape :indifferent14:
- Setup will be used mostly for Movies, Music, TV (in that order)
- No HTiBs - unless someone can really convince me that they are worth it!
- As future proof as possible while remaining in range of my budget
- Since it's my first attempt at HT setup, I am not inclined towards any particular brand.
~Vinod
