Need help for my first setup.
Sure, I really appreciate the help. Thanks, I will look into the reviews of the diamond series. And for AVR Marantz Cinema 60 is around 1.4L on online which is too high and its too much since this is my first setup. I will check the speakers and update here. Thanks for the help man!!
If you want to go for Diamond series, you can also consider Denon AVR X2800H which would pair well with Wharfedale. It can buy it for around 70K if you try with different dealers.
Hy, thanks for the suggestion. I ended up buying denon S770H and elac debut b6.2. Received the AVR. Waiting for the speakers
