First Time Setup Help
Dan9575
Brooklyn
Im looking to put together my first hi-fi system. Ive done a bunch of research already, but hoping for a bit of guidance before I pull the trigger and commit!
I plan on using it almost exclusively for music and listen to a wide range, from classical piano to house/electronic.
Speakers - 2 B&W 685s
I considered the 686s, but it seems like the relatively inexpensive bump up to the 685s is worth it
Sub B&W 608
I was thinking about trying with out the sub to begin with, but Im expecting I will need it. Im not looking to rattle my windows, but do want the bass to be present when called for.
Amp NAD C316BEE
I dont really need much in the way of features, just something basic and quality that is going to be able to drive the 685s. From what Ive read it seems like the NAD should have no problem with that.
I was also considering the Marantz PM5004, which has A and B outputs could those be used to bi-amp the speakers (never done this before)? And if so, is it worth doing? The Marantz is slightly more expensive and the output is 5 watts less.
Input Currently, the main input is going to be from my Macbook Pro or iPod via the 3.5mm jack with an RCA adapter. My space is about a 16 x 16 square studio apartment and the setup will go centered up against one of the walls
My question is basically am I missing anything obvious with this setup/is it a good choice for the money for a first time setup? Is there anything else I should consider or tweaks to the setup worth looking into?
Any thoughts appreciated!!
im not a big fan of the b&w 6 series. i also feel its over priced for the level of sound quality. you will get better speakers for less. this is obviously my opinion.
also the b&w's generally pair well with neutral to bright amps and the nad is definitely on the warmer side.
perhaps if you give us your listening habits (what sort of music), room size and budget we can help you build a setup to suit your requirements
I do agree about 685s.
I used 602S2, S3, 685,684, 683 & moved to CM7,CM1
In this 3 stage I found that 68 series doesn't match the real standards of B&W.
However I'm quite happy with my CM series now.
Might be you can try getting a 602S3 pair with the same Sub!!
This 602 is a meaty pair & would really deliver the classical B&W sound.
If you are stretching the budget then get a CM5 pair with a Velodyne Sub :licklips:
