FM not working on Sony 32BX320
jotba
New delhi
I tuned on FM Radio on my sony LCD 32VX320 but it not able to find any band. If someone know the setting please share.
hi jotba. You have made a correct decision. Its the best
hd tv in the 32 incher. I vil tell u the method 2 tune fm channels by 2day evening. How much u paid? And sure buy the 2yrs extended waranty by another 2k.
Thanx Rupam:), Jotba, just connect any co-axial cable to the television set and just go to the FM radio and tune it by using the directional keys. if your tv is connected to local cable by the rf terminl, then no need for any plugins !!!
yes I have taken cable connection..but the FM audio quality is not much clear as per sony the frequency comming through cable it not anough.
Can you also tell me how to stop noise when there is no signal..basically old TV has blue screen setting which mute the noise if not signal.
Guys, are you able to enjoy really FM thru TV or fancy of using the features:p. 100% the speakers in the LCD/LED TV are worst than the normal 2in1 set sold for 1000bucks:)
Also the current usage will be high for hearing those from crap speakers and also you are also making the TV get older(usage hours):cool:
