QA 3020i and Yamaha AX496.. source is a streamer cum dac based on raspberry pi.What speakers are you using? Which Yamaha?
Want to share a couple of short clips that I made of it, but don't know how to do so
Now don't tell your friend. He can call NAD backI am in love with the NAD, still laughing that I got it for free and taking my listening experience to new level.
Luckily he is not into music much, only a movie fan. He knows I am using it and saying good atleast you are using that crap, little does he know that it is a Diamond.Now don't tell your friend. He can call NAD back![]()
Sadly no, both are goneCan you give a small description on a comparison of your Sansui 217 II with the 320BEE. Which one did you find better on the basis of sound quality, synergy with speakers etc.
Most likely it will be the electrolytic caps. Electrolytic caps have a limited life and do need to be replaced.I recently checked out my father's 20+ year old 320BEE. It still sounds great (with KEF floor standers) but after a while i realised that the left channel was weak. Swapped speakers to confirm that the issue was the amp and not the speakers. Seems like the left channel is delivering less than half the output of the right one. Any thoughts on what could be the problem?
Thanks. Is it a relatively straightforward job that most repair shops can do?Most likely it will be the electrolytic caps. Electrolytic caps have a limited life and do need to be replaced.
It is straight forward but requires supervision. Else repair shops can put cheap chinese caps but charge you for the good caps. Take some help from this forum to get contacts of a good repair person.Thanks. Is it a relatively straightforward job that most repair shops can do?
Very nice amplifier. I took audition for this model way back in 2007 but as it was outdated the dealer arranged for C325bee for me. Very nice amplifier with excellent tonal quality. I am still using my NAD as my main amplifier with Wharfedale evo 4.1 speakers and it sound wonderful. I will try to answer a few of your ques as my amp has similar back panel.Around 6-8 months back my friend had come home and liked my HT setup. He casually told his uncle has a old amplifier which he is not using and you can take it, I told him to share pictures.
Thought of taking it and keeping at my farmhouse and get some super cheap used speakers to pair with it.
Last week he sent me the pictures, and it was a NAD 320BEE!! I checked on the Internet and researched a bit, called him and asked is his uncle really giving it away and he said yes, I told him I am collecting it this week.
NAD 320BEE has Pre Outs and Trigger inputs and Outputs. Can be used as Pre Amp or an integrated amplifier. These are the specs.
Got it home this week, I did not know will it work or not as it was lying unused. Opened it, vaccumed, cleaned whatever I could, heck I even polished it to look good. End result was satisfying, now was the main test! Will it work?
Did not want to use it on my new speakers, was skeptical so removed the puny miccas from height channels and tested.
First thing after turning it on, no lights for the inputs. I thought all of my happiness is gone, read online and found you need to select the input everytime you power it on. Voala, it started playing through aux and Activo CT10. Tested bass treble balance, even the tone defeat button worked.
Now wanted to test the pre outs, it was connected to the crowns and Q Accoustics 3050i. Wow, it sounded very good, slightly warm, highs are not sparkly but has a good signature to it. I thought the NAD and Crown combination would be bad. But sounded very nice.
Using as pre amp now, connected to Crown XLS.
Now Denon, NAD & Tube pre Amp all connected to Crown XLS via switch box.
Few questions, I have from FMs.
1) What does Mains Out do? It is next to pre outs.
2) Would I be able to get spare parts, was thinking to replace as much parts I can. And where can I get them in Mumbai?
3) Should I keep it or send it to my farmhouse?
4) I hear slight noise which is creeping in on the NAD only when no inputs are connected, as soon as I connect to the Activo C10 noise disappears, why could it be? How to remove it.
It will consume under 30W with no load , incl the preamp section which is Class A, if my memory serves me rightA quick query though, if the NAD amp is used as PreAmp, will it's power amp section still draw power and work as room heater?
Most of the NADs had Class A Pre Amp, I owned the NAD165bee pre amp for quite sometime and loved it.It will consume under 30W with no load , incl the preamp section which is Class A, if my memory serves me right
