Ashish6464
I want to build a new PC which will be used for 2 main tasks
1) Gaming (Max Payne 3,GTA San Andreas,GTA V,S, Call Of Duty, Far cry, Battlefield and NFS)
2) Connect to Home theater to watch movies. Home theater config ( Denon X1000 | Paradigm CT 100 | Panasonic PT AR100U | Vuemax 108" ) will need HDMI port in PC to connect to the Amplifier.
Need suggestion to build the PC so both the tasks can be done.
Or should I buy a gaming PC and a media player?
Budget around 30K max 35K.
Also for the above mentioned requirement should I go for i3 or i5 ?
this is a RIG options which I found online kindly tell me which will be best for my requirement.
Processor Intel i3 4150 7,500
Motherboard GIGABYTE GA-H81M-S 13,500
Memory Corsair Vengeance 4GB 1600MHz 2,500
Graphics Card Zotac GTX 750Ti 2GB 10,500
Power Supply Antec VP450P 2,500
Cabinet Cooler Master Elite 311 2,300
Internal Storage WD Caviar Blue 1TB HDD 3,500
Optical Drive Asus DRW-24D3ST DVD/RW 1,100
Total 31,100
thanks
Total 31,100
thanks
