analogadikt
GtM,
We first need to identify whether the problem is acoustical or electrical. Please try to carry out step by step checks as follows.
1) Power to all system components should be off to start with. Now, switch on power to the amp, select phono (switch on phono stage if you have stand alone one) and switch on the amp. If the hum starts now it is acoustic. You can push away the nearest speaker to the tt for a moment to check but it is very unlikely that the driver's magnetic field has any effect outside the box.
2)If all is well at the first stage then switch on power to the tt at the wall socket. after that flick the stop start lever and let the platter roll.
3) after this move the tonearm over the platter/record and again check by increasing volume. set down the stylus on the record.
Let us know exactly when the problem appears and goes away. Checks as above should enable us to pinpoint the nature of the problem although I believe that you have acoustic feedback and a sand tray under the turntable shall help contain that.
