guidance needed for establishing connection with onkyo ht s3300
kadirmkarthik
chidambaram,tamilnadu,india
The only problem in your setup is the TV.
If the TV has only composite or component inputs, you are out of luck.
To connect it to the HTPC you would have to purchase a VGA to composite/component converter and on top of that to get correct color reproduction you may have to purchase a transcoder.
You would be better off purchasing a graphics card with TV out or a TV tuner card then you could directly connect the TV to your HTPC.
For Onkyo HT-S3300, just connect it to the HTPC via HDMI.
k, but is there anyway to connect htpc to CRT tv via ht s3300.because it has composite and component connections.
