Happy Happy Happy
Suppu
Kozhikode
Bought yamaha yht 196 from RD
Rs 22,300/-
FREE
skyllcandy headset
5% cashback from Statebank Card. (will get only after one month)
In addition they (RD) give me
an HDMI cable
(that came free with some sony/sam/pany HT setup)
Is it good?
nothing written on it - only HDMI
And again the HDMI cable provided is for users to start using the product right out of the box. For better quality results you are better off getting a good branded HDMI cable.
For HDMI it does not matter... even unbranded local cable will do the same job as a $3000 Monster cable.
was the skullcandy offer on shop or you asked for it. i am also thinking of getting from RD or vijay sales. which is better, RD guy came to 22k and offered BDP for 3k which i dont want. getting ps3 in future.
Hey suppu.. good to know that you purchased this avr.
can you please help me in some of my queries regarding your purchase?
1) Does reliance digital give extended warranty for this ? did you purchse .. if yes.. how much additional did it cost.. and what does the extra warranty covers.. is it with the same terms as with the original one year offical manufacturer warranty? do they provide their resQ service for this item?
2) is yamaha known to fulfill warranties well.. i am really worried of the warranty served. in delhi.. as in delhi, there is one local sapphire electronics in my area which is listes as the official warranty provider for yamaha.. as you have gone for the purchse .. do you have any more details about the warranty..? in which area are you..
3) is it ok to buy this from snapdeal or infibeam.. ON their portal they only list the initial one year manufacturer warranty.. and dont talk anything of the extended warranty.. is it possible to purchase from them and apply for extended warrnaty from some other third party??
Thanks .. and how is your avr sounding.. hope it to be awsome..
waiting for your reply..
Bought Yamaha YHT-196 last week.
Just unboxed and installed the system, however getting strange problem, the Amp cuts off after a specific volume when listening with 5.1 setup. The culprit looks to be the Centre Speaker.
For Music - the music plays well for most of the Preset sound options but for 1 of the preset settings.
For movies, the amp cuts off when sound is set to 20 - 30% of the max volume in most of the preset sound options.
Did some R&D and figured out that all the modes where centre speaker is turned on, it does not works well and Amp powers off after a specific vlume. However if I switch to any mode where centre speaker is off. It works good.
Any pointer is any setting is incorrect or the setup is faulty or the hardware is faulty.
