Hardware Requirements for HTPC running XBMC
gaurav5
Delhi
hello guys,
I've been using xbmc on my apple tv2, though i love using it but i often face my apple tv getting stuck or restarting on its own. Also it doesn't support 1080p which was fine till now but i recently bought a benq w1080p projector and a grandview 120" screen.
I'm dont think i'll be able to build one on my own so i think i'm gonna find someone to assemble it for me. I did my research for hardware components but most posts are from 2012 and backwards.
i would request you guys to help me with the list of items ill need, I would want it running on windows so i can also do a little web surfing on the side if needed.
awaiting your inputs :)
Please check various thread under this HTPC section. You can also check a very long thread by Sam which is very informative and inspiring and motivated me to build my own (with assistance of a friend).
I built a htpc few moths back within 12-13K.... very satisfied with it. :)
Yes I have been going through Sam's thread for the past couple of days.
Can you please share the specifications of your htpc?
Combo Motherboard - Gigabyte GA E350N - Rs. 4567
DDR 3 2GB Ram Strontium - Rs1470
WD 2 GB HDD - Rs. 5197
PowerOn Cabinet with 450w SMPS - Rs.1050.
tplink wireless 300 adapter - Rs. 700
Total damage: Rs12984
Check this thread for more details.
