vellorenavin
but i have no issues playing high kbps streaming internet radio... but this would albeit be at a slightly lower bitrate than the videos. so what is the problem and where?
but reju how do you account for my pc beiong able to play / stream the same video jinx free on the same connection ? I.E how can the same connection be good enough for the pc and not good enough for the popcorn hour??? am really confused
reju i updated to the latest firmware and nmt suite two weeks ago. Do me a favour and try out youtube at lower speeds if thats possible and tell me if there is an issue. ? please?
I have sent you details by PM.
Reju faced any problems with the Elektron , especially after the mobo repair ?
No, it's working fine now.
I had taken 2 precautions after that.
1. Installed a smaller 2.5" 500GB portable HDD, instead of 3.5"
2. Installed a mini fan inside to blow hot air out.
Both these changes are taking care of the heating issue, which was the main reason I feel that my Eleketron had got spoiled earlier.
I have put pictures in this thread.
Can you tell what fan are you using in your EHP?? My EHP has 3.5inch HDD and there is no place to fit in a fan. My EHP is running fairly hot and i am concerned about the heat degradation of components inside the device.
