HDMI angle joints
mad
delhi
Any idea where I can buy HDMI angle joints online? My TV has three ports at the back, which makes it a bit difficult to stick in cables.
I checked ebay. They don't seem to inspire confidence. Any reliable online shop? Alternatively, if you know a place in Noida, please let me know.
Also looking for suggestions on HDMI cable. Longer is better?
check out the local Croma store - I bought a HDMI cable that was flat instead of round. It also came with a plastic elbow which can be attached to the end that attaches to the TV. The elbow prevents sharp bending of the cable so that it does not crack.
I need one..appreciate if you can share more info. What brand was this? Do you know if only the HDMI elbow was available seperately? TIA.
i dont recall the brand - I checked the cable and no there is no brand name. However there is the following lettering on the cable "82096 High Speed HDMI Cable with Ethernet E330476" - Hope this helps
Please check HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!, if it is not available locally. Got a few from them in the past and except for one issue with one angle connector, other cables etc are doing just fine. Lot of friends in US buy from them and are happy so far.
They are in california, USA. You might want to check with S/H/customs if it comes out cheaper to india. Hopefully customs on cable would not be expensive i hope.
