Hdmi port
hseplak
HI,
I have a query regarding hdmi port output, i want to connect a sony digital camera which has hdmi output port only to a normal CRT tv A/V input,can i get such type of coversion cable or am i out of luck? i know this is not the right place right forum to start a dicussion but kindly please help me.
thanks.
There are hdmi to component video cables and connectors available on amazon.com and ebay but do these products really work;ie digital to analog?????
HI,
thanks.
I think it is impossible to do what you have asked. HDMI is digital and A-V input is analogue. So an analogue - Digital converter mechanism is required. You may required to capture the video using the USB and convert it using a a Computer / laptop to do the conversion.
Enquire at the electronic streets in Bombay. ( Lamington street ?), there will be some thing avaiable.
^^ Thats not impossible, the HDMI to 5 RCA component AV Converter on Amazon does that exactly ....
Thanks sam9s and were in mumbai do you think i may find the convertor or do i have to rely on amazon or ebay?
I don't think these would work out. As this involves a conversion of digital signals to analog. And also split audio signals. Plus HDCP.
So I feel convertor like the one i listed in my first post is a must.
Beware that your CRT TV does not support HD resolution. One thing I am not sure is what happens when you send 1080p(16:9) signal in component cable. i.e will the TV automatically downscale or not. If your camera allows you to set the resolution/aspect ration for the HDMI, you need not worry about this aspect.
By the way, I have a Sony handycam. It does have a Component out along with HDMI out. So are you sure that the camera does not have other output options?
I have zeroed on sony cybershot hx100v camera would like to purchase it on dasera day,so i am conducting last minute checks,it has got one usb port also,as the salesmen at various outlets have no clue/knowledge about the product god knows how they sell these things???? so i am heavily relying on you people to help me out. thanks once again to all.
That particular camera has a AV out facility using which you can connect to your TV. You will need to buy Type3c-compliant USB/AV Cable sold by Sony. Refer this link : DSC-HX100/HX100V | Viewing an image on a Standard Definition (SD) TV | Cyber-shot User Guide
