Yelamanchili manohar
Wow....thanks a ton for sharing thatHi I was using a Melco N1A/ mark 2EX, which I switched to from a Qnap NAS. There was a drastic improvement in sound quality when moving from the NAS to the Melco. I remember just listening to 1 track is all it took to make my move. I also have the S100 which I use to rip the disks to the melco.
I have now upgraded my Melco to the N1-S38 as I have found Melco to be very reliable and I find them very musical.
I would highly recommend a Melco if you are looking for a server.
I have added the Melco S10 switch to my chain which had made a drastic difference in over SQ.
I just have a few more queries if you can please bear with me . Were your goodselves feeding your dac directly from the QNAP, when you switched to the melco N1A or were they both going into the network switch which you again replaced with a melco S10. Can you please also describe your before and after digital chain for my easier understanding.
In my use case scenario, I have a WDmyCloud Nas plugged into a router, with the Lumin plugged into the same router and feeding my dac either via Usb or coaxial. So was wondering if replacing the Nas with a Melco will be a noticable improvement.
The router will be replaced with a optimised switch down the line. Though which one Iam still not sure at the moment. But definitely not anything as fancy as the Melco S10
