photos pleaseee..
Luckily had one clicked.
photos pleaseee..
Ok. Ok. Ok. Now it get it. Yes. I believe you. But again my ears may not have picked out the difference as well. thanks. I have ls50 and love them with Parasound. But have been thinking to add a sub and upgrade the amplifier. I will take your vote for Hegel. Also if someone has a pointer to low cost DAC with builtin preamp and remote I would love to create a minimalist system with DAC, Power amp and speaker. Hegel will do it but if I keep my Parasound I would like to just add the dac and get rid of my bug preamp with tens of input options and sound processing options.Borrowed a friend's LS 50 for the occasion.
Excellent setup Otpidus....Do share your feedback on the Exposure monos...
Thank you Panditji. The amps are currently burning in with less than 20 hours on clock.
Congratulations, kindly share your experience on the amps.
Where did you buy the amps from?
Finally got Exposure 3010S2 Mono-blocks.
Congratulations Otpidus!
Congratulations on the power blocks. Any plans for a pre?
Whats the price sir
hi
did you consider an exposure 3010 s2 integrated ?
whats your pre-amp like ?
regards
I'm selling a my brand new Creek Classic A53 since I bought an Usher R1.5. The Creek is with the dealer since I took audition for about 4 or 5 hours loved it ,paid an advance then fell in love with the Usher and bought it. Let me know if you want it. You will get the full 1 year warranty with Bill in your name.
Congrats on your purchase the Exposures are a brilliant buy, I completely missed you bought your amplifier .... I would suggest you a Tube Pre Amp with the Exposures if you are in to Classic Rock and commercial stuff as I don't always listen to James Taylor or Diana Krall and the likes. That's what I found out off late.
Yes the Usher sounds superb,its a love at first sight and forever kinda amplifier, ( hence the creek advance was even looked over) yes heat ,weight and size are serious concerns and then the recurring cost of power bills,it consumes 55 watts even when switched off at its front panel but connected to the wall!!!!!!
55 Watts when connected but switched off !!! That's just mind blowing. This means the supply rail of your Usher is never disconnected and the super sized capacitors are cycled and trickled even when powered down.
