Hi all,
Of course, I must apologise first up for starting yet another thread.
I am this person:
Was thinking of a 7-8 feet from screen set up, but as good as the sound is, when the TV and speakers came, I realised am unwilling to give up on the immersion of say 5 feet from a 65-inch screen.
FM @RajithKumar was the first to point out the flaw in my plan - the heights just don't make sense.
Here is what I had in mind originally:
Will draw up a plan and share, but if anyone has used Alteco-type speakers as height speakers, would be much grateful if you could share your feedback.
Thanks and regards
And terribly, terribly sorry for the bother.
I am this person:
HT in a small 10x12 room at around Rs 3.5L
May become a long one soliciting suggestions and advice. Dear all, Been passively reading this forum ever since I decided to set up an HT. Trust me I have read so much in the last three months, and now I am left with more questions than when I knew nothing and started over. So, I thought I...
www.hifivision.com
Hi all, Just wiring the speakers. Can I leave them like this, or will they catch moisture? Should I snip the exposed part tight? Regards I have connected the Belden 8477 directly to the binding posts of the 3050i but that is a tinned copper cable. What cable are you using? If you're paranoid...
www.hifivision.com
Thanks and regards
