Hello everyone
Triple Ace
Cuttack, Odisha
This is my first post here. My journey started with the thought of buying a soundbar for my TV and after some online research and chat with friends i have finally decided to go for a budget AV receiver with Atmos and 5.1 speakers. The AV receiver i am planning to buy is Denon X1200W and the 5.1 set is Pioneer AJ series 5235ZT. Dunno if its a good combination but I am sure i will find out soon from the inputs of the Gurus here:-)
Someone suggested me Byford CRK6 with Kevlar cone two way or the Stonewater as my budget ceiling speakers.
This is just my initial thought but I am open to all your expert suggestions to make my HT set up better in any way possible.
Welcome to HFV, I am sure you will learn and enjoy the experiences and advice provided by our fellow members. Dont forget to browse posted forums which would have the answers required for the queries you have or challenges you face.all the besthappy browsing!
In terms of the suggested choice of AVR + Speakers, it should work well, check with different dealers and audition as many brands as possible and start shortlisting the ones that meet your requirement, connectivity, performance, appearance and of course budget......all the best....read related posts under Home Theatre or click on my name for similar posts....
Thanks for the quick reply efernand1 ..
I will check the related posts and derive as much idea/info as I can.
Can you guys kindly check the 2 ceiling speakers that i mentioned? Are they good? I cant find much info about the two here or may be I am unable to find the right threads.
I am planning to take the AJ 5.1 but with the woofer which comes with the 7.1 (S-MS3SW). Is it a good sub or shall I get the AJ 5.0 and buy the sub separately?
