Hello.. Friends Please help me as i need to get music system to my car.
gnaneshk
I am Gnanesh, new to this site.. i have booked my first car, Swift VDI last week and iam getting it on friday, 18 th of jan.. I want some info about Car sterio as i have no idea about car music system.. Guys can u help me to find the best possible set i can install in my budget of 15k - 20k. I am not very particular about the brand or looks. what i want is sound clarity and effect. i have no idea about subwoofer and all that stuff as i have never seen any of my frens installing such system.
Thanks for reply..
Well if you like more bass and will to spending a little more, I would suggest you to install a ARC mono block amplifier + JVC 1 Din Head unit + 6X9 inch Rockford Fosgate rear speakers + Rockford Fosgate 10 inch subwoofer. I have installed the same thing for my skoda ocativa
The total cost was 30k.
Believe me these are all imported and much much better than JBL,sony etc interms of build quality and also performance. May people don't know about ARC audio, they are really good
But I don't know whether a subwoofer will fit for a swift hatchback. But for head unit I would suggest you to go for JVC KD-X40 and if you need with bluetooth you can go for KD-X50BT around 8k
For a budget between 10k-20k (basic setup) JBL speakers + Pioneer Head unit do wonders. Its more than enough for a casual listening for all types of music.
Experienced lots times.
Just make sure whatever you get, its original and from trusted sources. Seen duplicates(especially speakers) heard to believe visually but sound proves. Experts can identify from some code and weight of the magnet.
Thanks for reply..
I have been using JBL dock from a year now and I personally admire with the user experience of it, sounds and beat clarity results are awesome! Also have a look on Sony or Bose they too have a very decent user reviews. Though I have a doubt for Bose whether they could be in your budget line or not.
However, when you go for purchase be very particular and careful for authenticity.
Hey Ganesh - Welcome to HFV.
Please also keep in mind that it is very important that it is installed correctly with the approriate wiring Etc as this is a key element to sound clarity. I suggest you get your ICE installed by somebody who knows what they are doing.
I see you are from Bangalore. Ive had good experiences from the following:
Satya from Evo - EVO - All About Sound , In Car Entertainment and More !
Satys is very knowledgable in this stream
Auto Fusion - Koramangala 7 Block
Probably one of the best and not very expensive.
+(91)-(80)-41505576
Cheers...
