rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,666
- Points
- 113
I have the e-mail address of the Chennai dealer. He has a website too. But i am not sure where i have saved. I will do my best to search for it
If you can, you just buy the monitors as of now and when you have enough funds you can go for the subwoofer - bx10
I have a friend who is using m-audio bx8a monitor and bx10 sub woofer and he said the sound is just amazing.
That friend of mine is a very big dj in india and a sound engineer and also in music production, so i can trust his word
Anupam, i really doubt the power will be less for you but i feel you should look for quality sound rather then quantity of sound. Then too just mention what is the size of your room
Someone from the forum can help you decide if that much power is enough for you.
Also did you check the Samson setup?
If it comes within your budget range it wont be a bad deal
