melody_lover
Hello members,
I'd never realised buying a HT could be as involved an exercise as its turned out to be, till I started doing some net search and discovered this site. Found some very useful stuff here, thanks to all for that.
I just moved to a new house, and am on the look-out for setting up a HT. Hall is 18'*12'; use is likely mainly towards TV viewing and music, with occassional movie watching. Budget is Rs. 50000 max. Have read through various posts clearly saying that HTIB typically wouldn't match up to a combination. Unfortunately, there's hardly anything possible with my budget. I'm a bit confused about a few things, will really appreciate some help on those.
1. I'm keen on having an AVR that has USB port, is that the right thing to insist, or does having teh USB port on the DVD player serve the same purpose?
2. Ideally how many minimum HDMI ports should one look for in the AVR? In my case, there will be very little or no gaming at all.
3. I'm not clear what 'audio over HMDI' means? And HD audio? How critical is that?
4. Have read some AVRs don't support video upscaling? What's that? How critical?
Overall, now debating between 2 very different options - 1. To go ahead with either Denon 1312 HTIB or Onkyo 5405 HTIB right now, and later think of upgrading the speakers, for better quality output.
2. To go with only AVR (Onkyo AVR 308 or Marantz SR 3053 or Denon 162 most likely) and front speakers (Wharfedale or Polk Audio 705 most likely) right now, and build up the rest of the HT later.
Request your thoughts, observations, comments, suggestions please. Most appreciated.
Thanks a ton.
rgds,
Kalpesh
Thanks a ton.
rgds,
Kalpesh
