Hello
SeanL420
Sylva
Thanks for letting me join this group. I have a question about my Yamaha receiver. It's reading internal error. What can I do to fix it?
Welcome to the forum! Nice to have you here.
You will also need to share the Yamaha model no to get better feedback.
Good luck!
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
