Audiophiles,
I visited some shops to audition to choose Home theatre.
The following are the constrainsts i have faced...
1. They don't have right clips. Just hooking some thing to play.
2. Even they will not tune the AVR to match the source what they are playing.
Expected help from the audio experts in the Forum
1. Best 5.1/7.1 sample clips can be downloaded from the net. (Not entire movie, only clips, but it should stretch the system to the MAX...Something like you feel, you are inside in the sound field)
2. Best settings for the receivers while playing the clips. [I hope each player has its own best settings for 5.1/7.1]
