warewolf4586
As stated in my another post in Receivers section, I have shortlisted for 3 bookshelf speakers and 2 Centres, and have to choose among them as per their compatibility with each other as well as with the bought receiver.
Shortlisted :
Fronts/Surrounds :
1) Polk Audio Rti A1 (5.25" woofer)
2) Klipsch R-15M (5.25" Woofer)
3) Pioneer BS-22-LR (4" woofer)
Centre :
1) Polk Audio CS10 (5.25" woofers)
2) Pioneer C22 (4" woofers)
Speakers Query (This would also depend on the finalised receiver ):
1) For a cheaper system my preference would be :
Klipsch R-15M (Fronts), Pioneer BS22LR (Surround/Rear), Pioneer C22 (Centre)
1st is that I am not sure if Klipsch and Pioneers do match acoustically.. (if Pioneers will go well with Warm sounding Klipsch or not)
Also, R15M is 5.25", Pioneer's bookshelf and centre are 4".. not sure if this combination works fine. And if it it does keep expansion room open. Are Centre and surround of 4" woofer sufficient ?
2) My choice without thinking of Costing would be
RTi-A1s (Front), R-15M (Surrounds) and CS10 (Centre)
as it makes all of them 5.25inch woofer.
Does that makes sense, and do these Polks go well with Klipsch ?
I am open on keeping any of the combinations, depending on them Blending well.
I hope no one will recommend to buy Rti A3 for Front and keep rtia1 for rear
, with CS10.. this will not only sky rocket my budget but also as I have to take them outside US, so will go beyond my baggage limit.
Shortlisted :
Fronts/Surrounds :
Centre :
![Stick Out Tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
