Help me to choose Home theatre
btmnayak
Guys,
I am planning to buy Onkyo TX-NR676 AVR,Please suggest me the suitable home theater(5.1.2 or 7.1) for the same.
My budget is less than 30K.
or looking for used Onkyo S5805 in Bangalore.
Onkyo model you opted is current running model i think.You may not get for the quoted price by u i beleive.
Happy Hunting :cool:
If you can mention room size it would be better. Also think of starting with a stereo pair and adding center surround and subwoofer later. For 30k you can get 5.1 speakers but you might end up craving for something better soon. Not a good situation to be in.;)
For <30K, very hard to squeeze a 5.1.2 set-up.. Best would be to pick a 5.0 set-up from Taga TAV series.. They come with FS and should fairly do the duty for the movies in the absence of sub (as you have budget constraints).. Add a sub later & then ceiling speakers / small BS speakers on ceiling when your budget permits..
Taga-Harmony-inMOVE-5-0 with one sub according to your budget( BS model)
taga harmony few more models with FS
As this FM mentioned, these are better models in your budget..
