HELP - Nakamichi cassette Deck 2 - Crawling
Selvin you should consider yourself lucky as the BIGGEST THIEVES r there in olx. Its infested with goons who r there to dupe you. And mind you very very few get a chance to inspect their product while buying through OLX.
I will still suggest all concerned,avoid Indian sellers who try to sell Nakamichi and high end vintages. Ebay is a 100% secured place and you get 3 months time which is a decent period to file a case and recover your money as a buyer if you wish to.
Thanks Deck_Help, Reuban, for the advice.
Its indeed my bad luck continuing with Tape's. After paying an insane price with assured goodies and extra belts none arrived till date. Today I have opened the deck and found the belt somewhat loose and some noise coming out from capstan motor so my doubt is either one is faulty. I am trying my level best to get a belt, luck didn't favoured yet.
Also to my surprise I found the PCB is wrapped upwards. Is it by design or due to age?
So to conclude this purchase, I just find it as DENTED AND PAINTED DECK from outside and scraps inside, which was made working temporarily and sold and this chap seems to be another scrap seller.
