@sam9s: Quite a detailed post!
Can you plz clarify:
"... that the 3D Bluray or any Bluray Movie content need 120Hz display. No it doesnt. ..."
I can understand that part for Non-3d content but for 3d content is it not requried to have 120Hz? There is no 48Hz (24x2) display mode for 3d or is it? Also the active 3d glasses have 120Hz 'refresh' rates.
".. the same content is been refreshed or displayed at 5 or 10 times a second 24x5=120Hz or 24x10=240Hz. Giving the image a false "smooth" appearance. ..."
If the SAME image is displayed multiple times how will that result in smoothing of the display? Unless some frame interpolation is done, there wont be any smoothing effect or is something else being done?
"... @ARN the converter you are buying is just to convert the conventional 2D content in to 3D, and might not provide you with enough depth ..."
The converter supports 120hz refresh rates so that 3d can be seen with the pj in question. Also, there is mention of 3d depth setting adjustment but dont know how good that is. Thus the convertor seems to be an option for PC-Ready / DLP pjs which need 120Hz. In these aspects is there any better alternative?
