legor17454
Hello everyone,
I recently purchased a 5.1 soundbar, but I'm having trouble with the clarity and volume of the vocals. The vocals don't sound very clear and are worse than the audio on my old LG TV. While the soundbar is good for action and horror movies, it has too much bass even in normal audio, which makes it challenging to enjoy vocal-heavy movies. I sometimes have to remove the subwoofer altogether.
I'm on a budget and considering investing in studio monitors as a solution. Can anyone recommend any budget-friendly studio monitor options that might work well for my needs? I'm open to any suggestions and appreciate any help you can provide. Thank you!
This is what i had purchased https://www.amazon.in/ZEBRONICS-BAR-9500WS-PRO-5-1/dp/B09QKZNMVD
