Help on setup
cistec
Australia
OK guys need some advice before Karaoke night.
I have a Wharfdale amp BX 1360SD = 4 Omhs 300 watt x 2
output is internal connected in parallel? 4 x 300 jacks output
Right/monitor x 2 jacks Left / Main speaker output x 2 Jacks
it states that you can connect one speaker with impedance between 4 & 8 ohms to one speaker socket or 2 speakers each with an impedance of between 8 and 16 ohms to each socket.
2 x Wharfdale EVP X15 dual Jack quarter and Duel Speakon inputs. 8ohms 300 continuous one side Jack/speakon is marked Parallel ?
2 x Wharfdale VS 12X Duel jack only parallel inputs. 125 watts continuous 8 ohms.
QUESTION. what is the best connection set up and can anybody who has the time to step by step show me clearly how to connect which cable into which socket on both sets of speakers and Amp correctly to gain maximum power. I have no idea about HI fi so kiddes gloves is reccomended.
or if finance available advice to add equipment to the setup to help make it easier. to anybody that replies I thank you and appreciate your imput.:rolleyes:
Thought I might upload a image of equipment so you can see.
