So which receiver u suggest around 20k ?
may be i add 2-3k more to it . That is why i was shifting to Philips DVD as that would have saved me 3-4 k . And i think i will go for Wharfadale 9.3 in my next upgrade so i will stick to 9.1 . But is dere appreciable change in 9.1 n 9.2 ?
Bro
Even in case you will be going in for Diamond 9.3 (BiPole Speakers) in future, but in any case you are not gonna throw your Diamond 9.2...
right...
Any how as 9.3 are bipole, they can only be used in for side surrounds, in a 7.1 setup...
Now.. 9.2 is better than 9.1, and the price difference is less..
so go in for that only..
Regarding the AVR.. go in for Denon AVR 1507...
you will get the same for Rs.22K approx...
Still try goin in for Pioneer DV 600 only..
As its better than any other in its class..
