Hi All,
i am about to start build my dedicated Dolby Atmos home theater room in my new ongoing constructed house, the size of the room is L-16.5 ft x B-13ft x H-9ft. i already have following equipment on board with me
Polk audio Rti A7 for front ,
Polk CSi A6 as a center channel ,
Bose dual cube as a surround,
Pioneer VSX 922K AV ( only using surround section of this amp)
Velodyne 15" Sub CHT 15 750 watt RMS,
Marantz MM9000 THX ultra 2 Certified 5 channel power amp rated 170 watt rms/ channel,
Pioneer BDP 170 Bluray Player
LG PA77u 720p Projector
i will upgrade to matching polk surround and dolby atmos amp later ,
i have separate stereo setup of wharfedale diamond 8.4 paired with NAD 319
this is room is for movies only not for music
now i have few queries related to equipment and acoustic
1. i am getting a good deal on JBL Pro Cinema Sub Model 4642A dual 18 inch drivers which will be pair with Crown CL2 amp, my query is this monster sub is a right choice for the room size i have or it is a over kill for this room, as of now am not able to decide. what in my mind is in moderate volume it will give depth to movie sound, following are the specs of subwoofer and crowm amp.
JBL Sub Specs
1200 Watts Continuous Pink Noise, 2400 Watts Continuous Program Power Handling
Usable response to 22 Hz (-10 dB, no EQ), flat to 22 Hz (-3 dB) with External EQ
Rated Impedance 4 ohms
Minimum Impedance 3.2 ohms
Power Handling Capability -
Continuous Pink Noise 1200 Watts
Continuous Program 2400 Watts
Peak Power 4800 Watts
Output Capability -
Axial Sensitivity 50 Hz to 500 Hz; 101 dB, 1W @ 1m
40 Hz to 100 Hz; 100 dB, 1W @ 1m
Net Weight 98 kg (216 lbs.)
Dimensions H x W x D 762 mm x 1219 mm x 610 mm
30 in x 48 in x 24 in
Crown CL2
CL2
*1 kHz Power: refers to max
8 ohm Stereo (per channel)-400W
4 ohm Stereo (per channel)-660W
2 ohm Stereo (per channel)-975W
4 ohm Bridge-Mono 1,950W
8 ohm Bridge-Mono 1,320W
*1 kHz Power: refers to maximum average power in watts
at 1 kHz with 0.5% THD.
CL2
2. My 2nd query if Expert FM answer is "yes" for above querry, than how will i can connect AV sub pre out to this crown amp because the connection types are completely different.
3. am not doing complete wall acoustic in my room rather covering main sound reflection points which i learned through available youtube video and room build threads,though i want to know is it important to do acoustic/ defuse area/wall behind screen.
i will ask few more questions as an when.
would request FM to answer my queries asap.
thanks in advance
JBL Sub Specs
Output Capability -
Crown CL2
CL2
CL2
thanks in advance
