Help required with PIONEER BDP-320
decibels
new delhi
I have recently purchased a Pioneer blu ray player (BDP-320).well everything is just fantastic,the 1080p resolution and the dolby true hd and dts master audio.The biggest problem comes when i play original dvd's purchsed here in india english movies only)from music world,planet m etc.the player shows an error which says incompatible region code.But it is playing all other dvd's---hindi purchased locally and other english dvd's which have been purchsed from usa and europe.
Is there a way to break the region code for playing dvd's from all regions.
Note:i am talking about dvd region code and not blu ray code.i only want a solution to make it region free in order to play all dvd's.
I would be more than delighted if anyone on the forum especially the senior members can come out with a solution please.
hi saikat,
Thanx for the reply.i will certainly try to find other available solutions as well.regarding your question for upscaling the BDP-320 is excellent but i prefer letting the av reciever do the upscaling.What i have done is connected all my sources to my Harman kardon avr 355 i.e:blu ray player,dvd and set top box thru hdmi to the reciever and then a hdmi goes from the reciever's monitor out to the pioneer kuro panel.
For this purpose u need to have a good av reciever which can do the upscaling and upconversion effectively.The effect is superb but is expensive because u need to have all the equipment with correct configuration to give u that wow effect.
Hi Decibels,
Quick query: where did you buy the Pio 320 from? Your profile says Delhi, so I am assuming it was somewhere in Delhi. Or have you imported it from the US, etc? Also, what price? Did you find any option for a zone-free and region-free Pio 320 in Delhi? I understand that while DVD region-free merely requires a firmware change, making players zone-free requires a hardware change.
Cheers!
