Gents - Issue not resolved
. Last night after about 45mins of play, the same issue occured with the speed dropping tremendously. Tried connecting the TT to multiple points but in vain.
Now, I did quite a bit of reading and apparently this is a Known Issue with some of the Akai Direct Drive TTs from that era.
Some tips I've gotten to resolve this issue:
1. Open the turntable and spray a Deoxidiser inside the pitch control and the 33/45 selector switch. Operate repeatedly to these controls to facilitate the action of Deoxidiser and then wait for a few minutes for complete evaporation.
This may solve the issue.
2. If the previous operation din't resolve the problem, then go to check all electrolytic capacitors and replace those that are not in optimal conditions. This requires use of a capacitance/ESR meter.
OR, just go ahead and replace all electrolytic capacitors.
Gents - Could you please advise on the above steps? Also, I've never opened a TT before and do you think I can go ahead and perform the above steps by opening the TT and not causing any damage? Or should I just give it to my TT Technician and advise him on the above steps.
Thanks in advance...
