Help!!!
kirsty1975
India
Hi All,
I need some inputs on buying a 46" Full HD LED TV in new delhi. Basic requirements are that I should be able to connect my external 1 TB HD to the LED to play movies. It should support all format .wmv/ mkv/ avi etc.
The sound quality should be good so that I don't need to buy the home thater immediately.
Please suggest the best model/ brand.
Look forward to your valuable inputs.
No tv support al the format , divx avi and some format can you can play but if you wanna enjoy full format with best pq ,buy any media player which start 3k ASUS .
samsung and lg support avi and mkv.
But I believe that your criteria for buying a tv are wrong IMHO
Buy a TV based on its picture quality and add a media player like asus oplay air, western digital xtreamer popcorn hour which cost much less than the tv 5-10k.
I have a 2 year old samsung series 6 led which plays via usb but i hardly use it. I use my oplay air which even has wifi.
Great. Thanks. I completely agree with your inputs. Any suggestions on best LED Full HD available in New Delhi which will the best VFM.
Thanks again.
Thanks.. Is it worth to buy from Gaffar? Can i buy it from Gaffar and take an AMC from Samsung or Sony in India?
Also, do you know of any good genuine dealers in Gaffar?
