Hi this is Aniket from Mumbai
adas
mumbai
Hi all ,
My name is aniket , i work in mumbai as electronics engineer ... had been into audio diy in the past, around last year 2016 jan the diy bug bit me again ...
and i made my first bookshelf speakers and sub .. with a sub ... and an amp ....it was real fun doing all of it by myself ...
regard
Welcome. Cool looking little amp. Looks like a Peachtree knob. Thanks for posting.
Sent from my HUAWEI P7-L10 using Tapatalk
Cool. Could you elaborate a bit more on the specs of the amp and speakers?
would be good info.
Amp is two channel TDA7293 putting out a modest 50W per channel at 4E , amp modules contain DC protection and delayed switch on circuit and the bookshelf speakers are a two way bass reflex enclosure tuned at 63Hz , cross over point for the mid bass and tweeter is 4500hz , the tweeter have a L -pad attenuation of -1.5db to match the mid bass. over all speaker sensitivity should be 89.5db at 1W at 1M ...
Oh and the it uses a 2nd order linkwitz- riley passive cross over...
Welcome to the forum Aniket.
Great DIY stuff you have achieved here. Could you share from where did you get the overall design or starter guide sort to achieve the same?
If possible would be building myself a Sub-woofer.
Cheers!
